Need help.. Built 6.4
Jgon08
Ok so I'm driving my truck (shones) old truck. I'm cruising along at say 30 mph normal driving and it all of a sudden looses all power no nothing it revs down to around 600rpm. Then it sits there a few seconds and then dies. Try and start it but nothing then try it agin it starts. I put in drive and has no power won't rev or even try to move at all.. Finally after it shuts off a few times it has power moves really slow but I get over the hill. Then I'm goin along get up to maybe 40 and all power is gone again same thing slows way down them shuts off.. Tey to start it and nothing get it running it revs fine this time then I take off and same thing again revs down the peddle dose nothing at all truck it's just barely running at about 5-600 rpms. I finally limp it home and put it in the garage. Anyone have a clue what I can look for all levels seem to be ok no leaks or anything.
08BIGRIG
WI
Is there any codes? That would be the first thing to check forsure. There should be something because its telling the truck to go into limp mode.
Jgon08
No codes or lights or anything, it's just funny cus I could start it would act normal then do die then another time it will just have nothing from the start..
White_monster
The great white north
Sounds like a communication between ecm error or a bad power or ground connection. I'd start checking grounds and power wires and be sure they are tight first and that they haven't corroded or come apart.
Jgon08
I was thinking electrical of some kind but I'm
Not even sure were to start.
HD F250
Washington DC
Spatel23
Olive Branch, MS
This must have been what you called about.....I was in a poker tournament so I couldn't answer.
Anyway....as others have mentioned, id start by checking grounds then move to fuel filter.
How many miles have you put on it since you got it ?
Jgon08
Yep it was, I checked a few grounds nothing yet. I'm leaning towards fuel, it's got right at 800 miles since I got it
