Need Help In Pagosa Springs CO ASAP
TXGLASSMAN
Keller Texas
Guys a good friend of mine is in Pagosa Springs CO on vacation.
he has a 2006 6.0 that has a crank no start issue and i need someone to go help him or if someone here can point him the right direction on where to find a diesel mechanic.
can anyone help??
TXGLASSMAN
Keller Texas
ive talked to JD lastnight and we found out that elite is 5 hours away. only option is to tow it there.
we are hoping someone close can come take a look and help him out where its at
drunk on diesel
is it trying to hit at all? no cold start or no hot start?
usually when a FICM or high pressure issue first rears its head, as long as he can get it to start, the truck will get him where he needs to go, just can't shut it off!
TXGLASSMAN
Keller Texas
no starting at all
but its a cold start issue, truck sat all night, went out to try to start the truck the next morning and nothing at all.
fordfreak4life
I don't really approve of this but turn the key on, leave it set a couple minutes, give it a snort of ether n if it starts head to elite and don't shut it off till they get it pulled in
Sent while spinning 18 wheels
TXGLASSMAN
Keller Texas
being towed to a local shop in pagosa as we speak, think we have nailed it down to either a FICM or a ICP issue. Im leaning towards ICP over the FICM
6.0 p-stroke
North of San Antonio, Tx
Although this could work, I wouldn't recommend it unless they're familiar with how to do it. Nothing worse than an engine running away, or worse, having the ether preignite from the glow plugs.
fordfreak4life
that's why you leave it set key on a few minutes to eliminate the glow plugs, I agree I don't approve of it but it does work as a last resort, doesn't take much to pop off a 6.0 just a snort
TXGLASSMAN
Keller Texas
Off to a local shop in pagosa
Hope they can get him on the road so he can get his family home to Texas
TXGLASSMAN
Keller Texas
Well to give you all an update. The truck made it back to Texas.
The issue and cause of all this
4 bad glow plugs. The truck wasn't equipped with a block heater until now. So once the truck was warmed up in a heated shop it fired right up and ran like normal. So it got a block heater installed and was plugged in the rest of the time it was in Colorado. I got the call this morning that they made it home safely last night and the truck did fine.
New glow plugs are going in this weekend
Thanks again to all
