Needing help loading tunes.
Jgon08
I just got some new tunes sent to me and some reason it keeps popping up no device found when I click on load custom tunes on the sct website. Am I missing something or is there more I need to do with my x4?
Turn your firewall off and reinstall the sct software. Leave it off to connect the device
03 7.3
Sct
I know this sounds simple but try unhooking everything (even the USB cord)
Restart your computer
Wait 5 min (let it boot up and load everything)
Then plug in your USB and SCT and see if it finds it
Jgon08
Is the tuner powering up when you connect it to the pc?
Yes it powers up that's why I thought it was odd the computer wouldn't read it .
And I'm using Windows 10 I thought maybe I needed a computer with Windows 8 on it
Kbuterbaugh04
There's some sort of command I think you need to manually enter or enable. Had that problem with my windows computer.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Ah windows 10 will do it...try a windows 7 computer
dieselpips
Washington State
I had the same issue yesterday with my windows 10 laptop. You need to install different drivers to get it to work. I found this website, followed the instructions and it worked for me. Good luck
https://support.bamaperformance.com/hc/en-us/articles/200801679-Windows-8-1-10-Driver-Update
I have windows 10 also and found that same link last nite doing a Google search. Just follow the instructions it will guide you through installing and unzipping the drivers you need to recognize the x4. It works
Sent from my SM-G920V using Tapatalk
Jgon08
Looks like I better give this a try I can't find any Windows 7 computers.
