White_monster
I've done heads a few times cab on. Let me know if I can help. Each time I did new gaskets and studs. By the way your build looks good.
Hope you got patience. The lower rear 2 bolts on the passenger side head come out with the head and the lower rear most bolt on the drivers side head comes out with the head as well. Studs go back the same way. Take your time too
am I the only one that thinks 60's on stock turbos is going to be a little too smokey?
A modded pump or twins would pay dividends with 60s or larger... hell, 2.3ms of PW won't even hold full pressure with stock nozzles.
I fully understand that there is a fuel supply issue with those nozzles. But tuning can be changed a little bit and whose to say that in 6 months that i dont go with a bigger pump or twins. I would just like to see how well 60s can do without a modded or twin pumps. If i lose power i lose power and that will get addressed but im pretty confident that wont be the case if tuned right.
My 60's seem to be over done with my twin pump kit.
well im doing pretty good right now. ive been struggling with the damn horizontal cooler for awhile now but i finally got it out. Other then that its just having the patience to work in tight places. Should have it completely tore down very soon and start installing all the parts. The reason its taking forever is due to the fact i rounded 2 of the exhaust up pipe bolts with a 6 point socket. Those really sucked getting out but its done now. Im getting excited to start installing everything.
good luck man.. pics help us understand and make your build funner for us
