New Elmo Truck
imelmo
Got's me a seat.....LOL
Then I guess I'm absent a seat. LOL
Just thinking out loud here on how the Nitrous is hooked up, right now and I have a little concern with it.
As air flows from front of the manifold to the back you will fill the first 3 cylinders with Nitrous from the front spray bar. All the Nitrous from the back spray bar will be going directly into the rear or last cylinder causing a very lean condition possible damaging the motor.
Just my 2 cents.
The rear two fittings get capped. Only the front ones will be hooked to solenoids. Same as the WOP drag truck from what I understand.
JDub
Hooper, Utah
Yes, but you could feed both ends if you wanted to. I believe on Elmos, 3AN fittings were used, same as mine and it picked up over 400hp on the dyno with spray using this spray bar design. With a progressive controller, you can modulate the solenoids and regulate how much spray is fed to them...
JAP
Diamondhead,MS
If anyone needs them, I have some 1/4 AN blank fittings that can be drilled for your HP goals.
imelmo
:pimp:
java
Texas
Make sure they weren't drinking before welding it back together.. LOL
Powerstroked162
On Da Juice
Wa. State
Anybody ever use a hobby(110v) welder on these frames?? Jason said he's gonna try to weld it up with some flux core wire. Im thinking a little more juice would be good but he said he wants to see how it fills the gaps first
kevin
springdale wa
The luck that Danny has with these motors I think it will hold fine:doh:
Cory S
orlando fl
i heard he was gonna do a core pass a torch and some brazing rod, and a cover pass with the flux core for rigidity.
