New Package today
Tncoalroller88
Piney Flats, Tennessee
Got home from work today and my new valair 600hp ceramic single disk clutch and flywheel came . anybody got any tips on putting one of these in a zf6 that will make it easier on me lol
2000wa250
A good tranny jack. An extra set of hands or 3. Time. Beer. Large vocabulary of your choice 4 letter words
2000wa250
Oh and possibly a bfh or dremel with a cut off wheel for the alignment pin.
Milford
Plainfield, IL
Not to highjack but which valair would you guys recommend to run with stage 2s? The 500hp one that is ceramic/kevlar?
Austin, Tx
The kevlar/ceramic works good with stage 2's. The engagement is a little grabby, but not too bad. I've also used the full ceramic with stage 2's and it also worked really good. Engagement is a bit more grabby than the kevlar/ceramic, but really once you learn how to drive it with either clutch, you can keep the jumping to a minimum. Now I have a ceramic sprung hub dual disc with my stage 2's and engagement is smoother than the single ceramic and 3rd gear launches are fun as hell. Still shifts quickly too. So, I'd pick between those 3 options and run with it.
Tncoalroller88
lol iv got the bfh will be renting a tranny jack have a buddy for some help will prob be getting a few beers lol and ask anyone that knows me i definetly have a large vocabulary filled with 4 letter words lol.. truck is still undercoated with profanity from stupid non fitting diamond eye exhaust lol thanks fellaz
Ad8 PRODIGY
Orange County, NY
Oh boy, that hurt to read. Grammar and punctuation please.
Good luck with the swap! :thumbup:
CAT35niner
NJ
Ive done mine by myself a few times. Get maybe 2 or 3 long pinch bars to help u line the bolt holes back up for a straight shot in. U might wanna put it on jackstands all around to help give urself some room to pull the trans back. Get a jack or somekind of support for the engine so it dont move around on ya. Plus all the other stuff that was mentioned could come in very handy lol, plus do remember to unplug all the sensors its not a good thing when something breaks cause u get in a rush, i should no :doh:LOL Have fun its gonna be worth all the :cursing: in the end
Tncoalroller88
Thanks for all the helpfull info my friend i will definetly keep it in mind. Plus i sure hope its worth all the effort lol
TyCorr
If an exhaust gave you trouble, you're in for a treat with the clutch. Buena Suerte!
2000wa250
Honestly I cant imagine doing it with an exhaust in place. When I did mine I was running just the downpipe, and I ended up pulling it completely to give us some more room. Have plenty of jackstands to support the transmission when its out, and also to spot it when you are putting it back in. Here's a quick run down on the process.
Pull into wherever you are doing it, make sure that it is someplace where you are comfortable leaving your truck overnight just in case.
Unplug the sensors and harness from the transmission and tuck up above the fuel pump on the frame rail.
Unplug the slave cylinder. Put it in the same general place as the sensors.
Get the transmission jack situated under the transmission. Make sure whatever you are on that the jack rolls easily.
Get in the cab and undo your shifter boot and manual transfer if you have it. Remove the shifter completely from the transmission, as well as the piece that actually goes into the transmission.
Hop back underneath and undo the transmission to engine bolts. Make sure you keep them somewhere safe.
Hop back up top and use either rachet straps or small chains to secure the transmission to the jack, unless you were able to rent one of the nice fancy jacks that actually bolts into your transmission.
Index both drive shafts and unbolt them. Move them off to the sides. Remember you will need red loctite for reassembly.
Remove the crossmember from the transmission, and then from the transmission. Make sure you remove all the bolts holding it on. There is a funky bracket on the passenger side. These bolts could be a real PITA.
Here's where the choice words and a couple buddies help. Get back underneath and begin to wiggle and push the transmission back. MAKE SURE TO CHALK YOUR REAR TIRES! Also before you remove the shifter put in in gear.
Once you bust your knuckles up a bit, and finally manage to wrestle the transmission back from the engine, make sure your input shaft is completely clear of the engine. Push it back another 6 inches if you can. Hop out from under the truck and enjoy a cold beverage of your choice.
Unbolt the pressure plate, remove your old clutch, and unbolt the ten bolts holding your flywheel to the crank. I believe they are 14mm.
Once you have your old clutch assembly out, remove your clutch fork and throw-out bearing if a new throw-out bearing is included in your kit. Make sure to note how it installs. The round bearing side is forward and it should snap into your clutch fork. Remove clutch fork and inspect it. Be careful with the pivot bushing, it is plastic and can break easily. I'd just buy a spare (or 2) from ford. They are only about 10 bucks a piece, and like I said are plastic and break easily (ask me how I know lol).
Install new pivot bushing if you so choose, then reinstall your clutch fork. Install new throwout bearing at the same time making sure it is the right way (again ask me how I know).
Bolt the new flywheel to the crank. You may have to either cut the alignment pin, or pound it in a bit in order to fit the new bolts in, depends on how thick your new flywheel is. I know with my southbend dual disk I had to cut about half an inch maybe a little more off of it in order to get the bolts to fit.
Line up your clutch disc using the mark on it (should be a bit of paint). Make sure that you have it facing the correct direction, it should be marked on the clutch.
Insert the alignment tool provided at this point to keep your clutch lined up with the flywheel.
Put your pressure plate on, again making sure the paint mark is lined up with the flywheel. Go ahead and start all the bolts so that you dont have to hold it, but do not tighten them more than finger tight.
Starting with one of them, tighten them in a star pattern. It helps to have someone on the front of the crank with a breaker bar turning the engine over to rotate the engine as you go. Tighten them equal amounts. Continue until they are all tight, then repeat one more time bring them to the torque specs provided in your kit.
Use some form of grease (vaseline works great) on the input shaft, making sure to wipe excess off so that it is only in the splines. DO NOT GET ANY ON YOUR CLUTCH DISC.
Have another cold beverage, you have completed the easy steps.
Prepare your vocabulary, and start moving the transmission forward. Once the input shaft is lined up and in the hole, have a buddy spin the output on the transfer case as you push the transmission forward. You should feel when it slips into the splines on your clutch. You will know it is in the clutch disc when the output does not spin freely anymore.
Keep pushing, wiggling, cussing, and doing whatever it takes to push the transmission forward until it is on the alignment pins. This will take some time. get it as close as possible to the block, if not all the way and completely flush.
Reinstall the bolts, tightening them slowly and equally. IF THEY ARE DIFFICULT TO INSTALL YOU DO NOT HAVE THE TRANSMISSION LINED UP CORRECTLY. Repeat the above step with added cussing until they insert easily.
Reinstall everything you removed, and dont forget to replug the sensors in.
While you have the top shifter assembly apart, it is a good time to change the fluid in the tranny. Remove the drain plug, let it empty, then replace the drain plug. Fill with MERCON IV ATF from the top where the shifter attaches since it is easier than the fill plug. Fill it until fluid is at the level of the fill plug. Reinstall fill plug and add a little bit more fluid to make up for the cooler.
Once it is all back together, enjoy a few more cold beverages, and then hold your breath when you start it.:toast:
If you are having problems getting the transmission to suck all the way in, you can install the slave cylinder and press the clutch in to see if that helps you. If there is any solid resistance to the clutch pedal DO NOT PUSH THROUGH IT, YOU WILL BREAK THE PIVOT BUSHING. (again ask me how I know).
Ford should have a pivot bushing on the shelf. I know when I called to get one, the guy said its something they keep stocked because it is a common part to break.
PM me if you run into any issues. I'm guessing that because it is a single disc it should be a little bit easier install than a dual disc.
Remember that your new clutch will require a break in period, and may change how it feels. Do not be surprised if it continually drives a little different every time for the first 4 or 500 miles.
ENJOY THE GOOD CLUTCH!!!!
TyCorr
For real, it's a tech thread on a diesel forum not english class.
I used perfect grammar and punctuation when I.used to post on a laptop. Now Im on the phone my contributions.are chockful of errors and splattered with errant.periods. :doh:
2000wa250
Mine has this mod in the interior and engine comparment as well....LOL
I like to think, my truck requires a donation from me every time I do any modding. As a rule of thumb, the bigger the job the more serious the donation. Generally it is simply a few choice words, but it has been known to crave blood, sweat, but no tears yet....knock on wood
