nitrous???
GROSSpolluter
So Cal
I just want a small bottle to go behind thr back seat for dyno events and a drag race here and there. What do you guys recommend and how are you activating it... Push button or throttle signal? I already have 2 bungs welded in my nolimit pipe so 2 stage is an option. Is there a controller or what for 2 stage.? Or should i just get a old Nintendo controller for a and b button HAHA
Dzchey21
wyoming
i used my horn button for a long time because it was easy, already on a relay and totally stealth LOL
You can use a WOT switch too or something of that nature
Most drag strips wont let you have a bottle in the cab without a vent to the outside of the cab, that is if they see it...
JDub
Hooper, Utah
Any of the basic diesel nitrous systems should have everything you need. Some come with a wot switch, some with a hand held button. It's really up to you...
bigrpowr
<How I Fly
Administrator
I guess my simple answer wasn't enough Justin? A 10lb bottle fits on the frame rail , spray a .100 or so jet on the up fitter or horn, on the Dyno hit it whenever u want , for me it always been around 24-2500 , and right after 1-2 shift at track. Don't over complicate something very remedial.
GROSSpolluter
So Cal
Yeh i know I just wanted to see what set ups people are running.
Mike@MPD
Pasadena,MD
You can get a line lock or trans brake button and arm it with the up fitter switch. I just had a .136 wot out the hole and a .136 for 2nd on a push button on stock everything
Sent by my Nexus powered by this (╯°□°)╯
Irontx
Texas
Mines behind the seat with Blow down and a remote bottle opener. Activated with a wot switch plus a hobs switch. Easy!!!! Kit came with most of it. Think i got a .088 or a .100 in there.
