No power/stalling
baddkarmaracing
harlingen,tx
I have a 99 f550 wrecker at work that has been having intermittent no power and stalling issues.
Codes I'm getting are
p0603 internal control module kam
P1316 idm codes detected
P1247 boost pressure low
P0340 cps circuit fault
What are the normal causes for these codes?
baddkarmaracing
harlingen,tx
i ran the koeo test and got :
p1277 cyl7 (c) high to low side open
p1293 high side open bank1
p1294 high side open bank2
and koer code only got p0476
for some reason when i ran a contribution test it would never go thru the test. buzz test got gave me the same codes as KOEO
Tom S
With those codes I bet it is often not running on all 8 cylinders.
baddkarmaracing
harlingen,tx
What should I look for? I know the Cps is new. I guess something else worth mentioning is It is hard to start in the mornings but when it does start it runs fine. Almost acts likes its not firing when it does it. Cranks fast (new starter) and sounds good but just takes forever to actually fire up. It doesnt act like a gp issue
JLDickmon
get in the data stream and look at the ICP data.. and then check the plug at the ICP sensor for oil contamination and possible bad ICP sensor
plus it sounds like it's either got a couple of flaky UVH's or possible a couple of injectors headed south..
baddkarmaracing
harlingen,tx
Not sure why I didnt think of icp. I took notes of all kinds if stuff but not icp yesterday. If I have a chance today I will put the scanner back on it and check that. It might Have to wait till tomorrow because today is my busiest day of the week.
Anything else I should look at while I'm there?
JLDickmon
I still think it's got two problems...
pull the plug off the sensor and see if it's flooded with oil....
that funky buzz test is making me think very high resistance between an injector and
ground... could be the #2, which was the first problem child, could be one of the odd-bank ones, given that they were affected as well..
baddkarmaracing
harlingen,tx
Just picked up a cps from a friend so we can see if maybe the new one is bad.
He thinks the Idm may have gone out but since I can't read the Idm codes it's hard to tell.
Btw friend is actually a ford diesel tech
