oneturboforme
- Joined
- Sep 12, 2011
- Messages
- 1,040
- Reaction score
- 0
Replaced my injectors hpop springs pushrods studs. Anyways seemed to start up fine at first. It was idling rough so I took it for a 90 mile trip still had a funny miss. Thought it was a tuning issue no big deal shut the truck off. Couldn't get it started cranks but no start. Pulled the chip still crank no start. Changed out the cps with a ****ty one from orileys tach bounces when cranking. Once in awhile it will start after prolonged cranking (more than 20sec seems like only after I fully charge the battery's battery's are only 10 months old. Truck has WTS light and an irate regulated return gauge shows 65psi. Hooked it up to a snap on scanner only thing that looked weird was even with the icp sensor unplugged it still showed the pressure increasing while cranking. Swapped the ipr with a new one still no change. What now?
