bluedge8
I guess it's my turn for a no start. here is the back story:
Over a month ago I started my Joe Daddy tight wad mod due to a chronic and pretty bad fuel leak in the valley from the fuel bowl. So I gutted the bowl and and related stuff then pushed the truck into the driveway and proceeded to clean the engine with simple green and a regular garden hose. I pushed the truck back into the garage and started cutting up the fuel pressure regulator and setting up my remote fuel filter. I had to leave out of town for work so I temped in the fuel filter and tried to start it. It cranked awhile then started, seemed to run on all eight, then it started to run rough so I stepped on the throttle and it wouldn't rev up at all and as I let off the throttle and it died. I didn't have time to deal with it until now. I did notice that my fittings at the fuel filter were leaking so I fixed those and tried to restart it tonight and it cranked awhile then fired on one or 2 cyl's and that was it. After that it just cranked and would not fire. So I was thinking that maybe I fried the injector wiring to the uvch's but the connection looked good. I do not have AE but have a Scangauge, I did a buzz test and they all sounded good. I checked dc and it was around 47% while cranking. icp while cranking went slowly then rose to 3200 or so and stayed there while cranking. I was thinking that water in the wiring was my main problem. I have wts light, and tach moves when cranking. A list of ideas please and thank you!
