Not charging
taylorv0000
Lapeer, MI
I have a 95 7.3l, it's not charging and no battery light. I swapped the alternator with a good working one from one of my other truck's and I checked all the fuses and checked the instrument cluster to see if I had a burned out bulb and nothing. Someone please help or at least point me in the right direction
Sent from my HTCONE using Tapatalk
heavydoc
Cruso, NC
12v should be on the little wire to excite the alternator field.
Sent from my SM-N920V using Tapatalk
taylorv0000
Lapeer, MI
Ok thanks, are you thinking far left of the alternator and above the output post?
heavydoc
Cruso, NC
But like I said I swapped it out with a good alternator, my guess is it's some were in the cab
I must have missed that post. Some of those trucks had a fuse and or relay on the engine side of the firewall, but I think those were on the gas versions.
heavydoc
Cruso, NC
Should probably find a schematic and see were power comes from.
taylorv0000
Lapeer, MI
I do have a oem Ford 7.3l service manual, but it shows there's a fuse in the fuse block. But there's not so idk what to go by
