odbii reader not reading
zabeard
I have a scangaugeII which I have heard a few members say it works fine on their 1997 which is what I have. Scangauge says there are exceptions on 97 Ford Diesels, but I imagine it still works just not all functions?
I am trying to get mine to read on this new to me truck. It just says connecting. So I know its getting power.
I tried a reader from O'reily Auto parts and it couldnt connect either?
I checked the fuse in the dash and it had a 10AMP fuse which was blown but then had a small wire taped between the terminals as if someone bypassed a blown fuse ??
Any rate i put in a 15 amp fuse like the manual calls for and still no luck.
Any suggestions on where I could start looking to correct this issue? I just want some kind of reader to work.
Thanks!
zabeard
I did not. I will check that.
I would think if the scangauge turns on its getting power, its just not communicating with the PCM?
