There is a night and day difference in pressure build time with just a 10 degree C rise in temp. If it were a priming issue, temp would either not effect or make it worse not better. My truck is a 6.4 and this is obviously a 6.0, so there are differences in some of the oil path and volume. I know for a fact that vis is playing an issue, I do this kind of engineering for a living, and get paid very well to do it. But you won't know until you try. Just make sure you don't restrict volume too much, and make sure its a high quality seal in the valve. You don't need it coming apart and causing trouble down stream.
