F.X.5
I have an 08 Job 1 6.4 CCLB 4x4 I purchased last fall and I'm working on making sure everything is in good working condition before driving it much this summer. Its Spartan tuned and fully deleted with 130k miles. I noticed the other night that when in the throttle (engine load 30%+) the oil temp rises fairly rapidly and takes a long time (more than I think it should) to cool back down. Sometimes my ect and eot will be 20 degrees different, oil being the warmer of the two. I'm assuming my oil cooler may be starting to clog up and to my knowlege it is original.
I've been doing some research and haven't really come up with much info on the oil coolers on the market (other than the factory Ford cooler). I was wondering if an aftermarket cooler (if availiable) was worth the extra cash or if going with a Ford cooler would be fine? I'm also assuming the oil cooler is located under the turbos? Didn't find much info on replacing them either, alot for the 6.0, not much for the 6.4. Let me know what ya think. Thanks.
