Oil leak out of HPOP new HPOP questions
TurboM700
Minnesota
Well I have had these leak for a long time. I first replaced the o-rings on the turbo and pedestal and deleted the EBV and the leak seemed to have gotten worse.:doh: It only leaks when shut off.:doh:
Fast forward to a few min ago and I'm out in the gargae looking to see what else could be leaking in the valley and the plug that sticks right out of the back of the HPOP is leaking I can clearly see that it drips oil out of it.
What are my options to fix this?
The truck has almost 100k is mostly stock except tuner and upgrade cold side of the turbo along with the usually stuff.
Aftermarket HPOP?
Dealer HPOP?
Rebuild the old one?
Whats everyone thought on this?
Thanks
Mike
TurboM700
Minnesota
Went a picked up the kit and did it. Thanks a ton I think you saved me from buying a new HPOP
Thanks
Mike
Tom S
There is also kit that has a longer threaded plug for that one spot on the HPOP. I need to remember where that info is at.
