Oil Leak
Jlyl248
Alright well I noticed two spots in the driveway and looked under to see that there was oil on top of the pan and all down the sides,its a slow leak it seems. I just had my egr delete with wastegate installed tues,they removed the cab. I don't recall a leak before,could this be a result of something from the cab removal or is there something else gone wrong? Thanks
greasltn
Hillsborough, NC
Is it mostly on the drivers side? When I do an EGR delete I remove the dipstick tube, it makes it easier. If the O-ring on the dipstick tube is not seated properly, it will leak.
Jlyl248
Ah its kinda hard to say. Because I can't see exactly where the leak is from, just where the oil is running. It wasn't leaking before I know that. I hope its not the rear main seal, i'll call them in the morning I guess, his work carries a year guarantee
Shipmate
WA.
Check for a crack in the dipstick right where it bolts to the head via the 10mm bolt. Mine had a crack right there.
Jlyl248
Yeah, im just skeptical with not having the leak before the cab was off, so I wasn't sure if they pinched a line putting it back on or like stated above with the dipstick tube
Jlyl248
It's the o ring on the dipstick tube, covered under installers pocket
Jlyl248
Yeah it hasnt gotten there yet so its not fixed, im not sure of the part number. Check with sunrise and get a discount bud
