On a scale of 1-10 I Have problem that ranks n about 9.6
kamikaze jr
Langhorne,PA
I dropped a peice of a pick down my engine dipstick chute.
Has anybody else done this wTF do I do
Besides not crank it over ever again
Please help
Dmstrucks02
Pearland, TX
Drain the oil and put some kind of screen in the flow and see if you catch it
Sent from my SAMSUNG-SGH-I537 using Tapatalk
ghohouston
Lewisville,Texas
Likely it will sit in the bottom of your oil pan forever and you won't ever know its there. Maybe use a bigger pic next time so this can't happen
drunk on diesel
I wouldn't worry about it. Steel doesn't float. And oil is lighter than water.
Drop a washer or something in a jug of oil and see if you can even get it to budge off of the bottom my shaking the jug.
Unless you're planning on driving upside down, you'll be fine
vcassens
Godfrey,il
I understand what you are saying and I wished it worked like that but if it did I wouldn't have had needle bearings go through my oil system and wipe out my motor
Sent from my SPH-L900 using Tapatalk
Dmstrucks02
Pearland, TX
You might be fine if you don't catch it. Hopefully it's on the drain plug magnet, I would make an attempt to flush and try to catch it
How did needle bearings get in the oil?
Buck1
Winchester, IN
Slap a big magnet or 2 on the outside of the pan for extra insurance (assume steel pan) Run it around, next oil change, slide the over by the drain and see if you get lucky.
