Overhead display
Flounder_Pounder
Spring Branch Tx
If its the usual failure you can fix it yourself for free. Hardest part is getting it off.
The usual problem is the chip capacitors fall off and need to be soldered back on.
dzldoctor
There is another with id of mandigital, I have used him before and he is in my state so quick service. Have had him do a few different electronic modules with good luck.
Fordguy100
Silverton, Or
Its an easy solder job. First time I ever soldered, and I got it done in like 2 minutes. Behind the display portion there are 7 resistors, I guess they didnt get soldered down good from the factory. Look to see if any are at an angle, or missing (in which case they should be in the overhead console somewhere). Just solder back on, or solder over the old solder and your golden.
They are on the other side of that display.
THETANK01
Just tore mine down and found 3 of the 7 laying in a puddle of water up there.
Sent from the drivers seat.
Platinum250
Laramie, WY
Mine doesn't currently work either. I pulled it apart and noticed 2 of the 7 resistors laying in the case so I tried to solder them back on. Not as easy as most people say it is. I was using small rosin core solder and a small pencil soldering iron. The resistors and spaces are very small and it is hard to get the solder right on to place. I ended up shorting my circuit board out so when I plugged it back in I lost my dash and throttle peddle. Easy fix, just unplug and replace the 2 fuses I blew. :doh:
