p 1000
fyrehose
Does anyone have a quick way to clear this damn code so i can get my truck smogged
Zmann
they plug in to the OBD and look for codes were your from ?
just lit CEL's on the dash for us
tell em you needed batteries WTH ?
Mark Kovalsky
SE Florida, USA
The ONLY way to get rid of the code is to drive it enough so that all the OBDII tests run. It can take quite a while. It takes stop and go and quite a bit of constant throttle, constant speed driving.
JLDickmon
:doh:
P1000 is drive cycle incomplete
don't recheck for codes after you clear the codes..
clear the codes, unplug the scanner and go about your business..
if you clear it, then go back to check it, you're setting it yourself.
Zmann
that must be a 7.3 thing?
mine (6.0) you can check all day long and when I clear it with the cts or A/E the
1000 is never present like if I disconnect the batts
JLDickmon
uuuuummmmmmmm sure!
Be honest, I don't see it on everything I work on day-to-day...
must be whatever the software geeks wrote into the program..
