Does anyone have a quick way to clear this damn code so i can get my truck smogged
Mar 30, 2013 #1 fyrehose New member Joined May 22, 2011 Messages 31 Reaction score 0 Does anyone have a quick way to clear this damn code so i can get my truck smogged
Mar 30, 2013 #2 purpleheart350 New member Joined May 19, 2011 Messages 1,000 Reaction score 0 Location Rokwall, Tx Drive 50 miles
Mar 30, 2013 #3 Zmann New member Joined Aug 5, 2011 Messages 4,464 Reaction score 1 they plug in to the OBD and look for codes were your from ? just lit CEL's on the dash for us tell em you needed batteries WTH ?
Mar 30, 2013 #4 Mark Kovalsky Active member Joined Jul 11, 2011 Messages 1,195 Reaction score 12 Location SE Florida, USA The ONLY way to get rid of the code is to drive it enough so that all the OBDII tests run. It can take quite a while. It takes stop and go and quite a bit of constant throttle, constant speed driving.
Apr 1, 2013 #5 fyrehose New member Joined May 22, 2011 Messages 31 Reaction score 0 250 miles to clear the code
Apr 1, 2013 #6 JLDickmon New member Joined May 25, 2011 Messages 2,149 Reaction score 0 Location 49048 :doh: P1000 is drive cycle incomplete don't recheck for codes after you clear the codes.. clear the codes, unplug the scanner and go about your business.. if you clear it, then go back to check it, you're setting it yourself.
Apr 1, 2013 #7 Zmann New member Joined Aug 5, 2011 Messages 4,464 Reaction score 1 that must be a 7.3 thing? mine (6.0) you can check all day long and when I clear it with the cts or A/E the 1000 is never present like if I disconnect the batts
Apr 1, 2013 #8 JLDickmon New member Joined May 25, 2011 Messages 2,149 Reaction score 0 Location 49048 uuuuummmmmmmm sure! Be honest, I don't see it on everything I work on day-to-day... must be whatever the software geeks wrote into the program..
