Yesterday I noticed my CEL and abs lights were on after I got to work. I have a cold air intake, the dpf deleted, full egr delete (coolers and valve/elbow), and an h&s minimax tuner with can tunes. The minimax pulled the following codes:
P1639- vehicle id block not programmed correctly.
P163A- ford generator B control circuit.
P0603- internal control module keep alive memory (KAM) error.
I was able to clear all except the P1639 code.
I can not re-program the truck or return it to stock tuning and get a locked screen reading "Downloader Is installed on truck with this vin "(gives my trucks correct vin)" please return to stock" after completing the tuning sequence in what appears a successful manner as normal.
I haven't noticed any issues except lately when it gets cold if I don't wait for the glow plug light to go out plus give it some extra time, when I turn the key it cranks about halfway over, stutters/pauses/ shorts like the batteries are dead, then continues to crank, fire and idle normally.
Any ideas or advice how to fix the start and tuning problems would be greatly appreciated.
I apologize if this has been covered but the search function isn't working on my phone and my laptop is dead due to too much internet porn.
-Cyrus
-Cyrus
