p1705 code and how to find possible leaks
Ozzyedd
sedro-wolley WA
Hi i have a p1705 code which translates to TR Sensor Park/Neutral switch out of range, i am going to change out the sensor on the tranny as i think this is why my A.I.C. isn't working, does sound like the right place to start & i have a couple of others which are P0472 which t think is related to the EBPV disconnected and a P0500 VSS, but I'm not too concerned with that as cruise and speedo both work fine and its always been there, the other thing is how do i look/check for turbo & boost leaks,i always have this weird exhaust smell around the front and front/sides of the truck, I've checked the exhaust right up the flange out of the turbo and i can't feel any leaks ...Thx Ozzy
baderic03
warren ri
start the truck at idle and feel around the up pipes if you can for leaks,check your manifolds,check the turbo mount for soot and leaks, check your intake y and boots and all the clamps. how much oil is around the boots
