parallel turbos?
drunk on diesel
most gas setups have cylinder heads that flow and don't run 40-60psi of boost.
they might make 800hp at 15psi
compressor map compressor map compressor map compressor map compressor map
superpsd
Missouri
Sequential setups are not compound setups. They usually use a smaller turbo for low end response then a gated system lets a larger turbo charger come on line as exhaust volume increased to be able to push a larger turbo. Some years of the Supra I think came like this.
I have seen some gasser setups where only the compressors were compounded. Most gassers however do not use 80 psi. Most street gassers are pushing 20-30 psi and that's about it. Higher PR and your usually talking drag only cars.
Compounds are how you can achieve high pressure ratios as the boost is not added when compounded its multiplied with multiple variables.
Wes Lewis
Pittsburgh PA
Parallel turbos are more for top end, little harder to spool but can move a lot of air once they are lit. Common in gas engines because they run smaller turbos, then gate them on the top end, and have a lot of air flow over a wide rpm range.
superpsd
Missouri
It all comes down to the turbocharger specs. CFM for CFM smaller twin turbos versus a larger single will spool quicker and have more street manners. The single will be laggy but pull harder up top due to less exhaust restriction. Turbine housing sizes play a huge part of the balance. Smaller housing as in the smaller ratio bottleneck will create faster response with reduced higher rpm power due to higher backpressure. A larger housing will be laggy at lower flow and great at full tilt as the exhaust restriction has been reduced. I have simply taken the turbine housings on a few of my builds and ported the housings to increase high rpm power at the expense of a little low end response.
There are other things that can improve response however. Ball bearing turbos, spool valves, nitrous, ceramic coatings to keep the exhaust temps contained in the hotside (hotter exhaust gases move at higher velocity) and more.
thatsmokinobs
SW Pennsylvania
So what I'm getting from this, is that parallel turbos are similar to 2 pumps on a hydraulic system. With one pump, you'll produce 2000 psi and say, 20 gpm, and with 2 pumps, you still make 2000 psi but 40 gpm. So with one turbo, 20 psi and X CFM, and two turbos, 20 psi and roughly 2X CFM, correct? So it would be more for high performance/ high rpm applications vs street driven?
97stoker350
south central pa
Itl drive no matter what setup u put on it but what they are getting at is its just mo ey and time down the drain when a 468-75 will do everything heui could ever hope to accomplish... On a street truck
drunk on diesel
here's the thing... you can actually figure out if it's going to work if you have cylinder head flow data, projected horsepower levels, and know how to read a compressor map.
no one is going to spend the time to do the research on your daydream, unfortunately.
2nd best bet is to mimic a combination that someone else has used that has worked well. Most people who have put together successful combos haven't wasted their time with parallel turbos. As such, you probably won't find a proven parallel turbo combo to mimic. I've certainly never seen one under the hood of a Ford, Dodge, or GM diesel pickup, and I've been doing this diesel **** for almost 20yrs.
I've also never attempted it because I try not to waste time and money
Bustedknuckles
Confederate diesel had parallel EFR's on their 6.7 for awhile, went back to a big single though.
drunk on diesel
