Hey guys could use some help...its not a powerstroke but an 08 v10 f450 xl 6spd man.i updated the pcm with an ids, everything went fine.. But no crank.. Jump it out under the hood and starts up fine. Datalog shows that the starter relay is disabled...
Its an xl truck so it doesn't have a chip key.. Is there a different way to program after parameter reset?
I've tried programmable module install on both pcm and cluster, along with pats parameter reset..
I did get a P144c code to show up once, cleared and hasn't been back since
Any help on this is appreciated
Sent from my CLT-L29 using Tapatalk
