Pcm code help!!!!
2000BigDirty7.3
So im an idiot and managed to fry my pcm (I believe) in my 7.3 but cant find much on the stamped code, the sticker is gone, heres the code
f7tf-14a638 ac
It's a 2000 f250 7.3 auto 4x4
Sent from my HTC One M9 using Tapatalk
Justin@DP-Tuner
As long as it is not a California model truck, then your code will be NVK3 or NVK4 (either one will work as a replacement. Any DPC-422 will work for that matter).
2000BigDirty7.3
Why does this one register as a 97 in part numbers? And no I'm from Ontario.
Justin@DP-Tuner
The part number you listed comes up on a bunch of different PCM's. I believe it is the part number for the PCM case?
so something like that would work for sure?
Yes, a DPC-422 will work for you.
2000BigDirty7.3
Yes it's the one stamped on the case, the sticker was gone off it
JLDickmon
could call a Ford parts room and give them the VIN.. they would probably be able to look it up
2000BigDirty7.3
The things you do when your pissed off, I ripped the chip out while it was running
2000BigDirty7.3
Just picked up a computer from a buddy with a sd scrap yard in fergus ontario, 150 bucks it's a dpc-422 nvk4, going home to try it out
What's the name of the scrap yard?
