PCM shorting
Jomax
Arizona
Early 99 truck 280k 7.3 4x4
Truck was converted to a dpc-422 pcm family when 250/100% injectors were installed. Truck ran great for 10k miles, so I don't think it was was installation.
First chip was a dp F6, second one was a F5
Truck died driving to CA with the first chip and pcm, cut out and died like a cps. Chip light went out. After unplugging the chip truck still wouldn't start. So I had my brother bring me my spare pcm same pcm family. Installed it and drove it 60 miles home on stock splitshot tuning...
Truck sat over the new years week and i just installed the chip this tuesday. Drove it 500miles and now the second pcm and chip are shot same symptoms..
Sucky part is those pcms are hard to find...
Anyone have this kind of problem? Any schematics of the wiring for the pcm? What values should I be seeing?
Jomax
Arizona
But two bad chips in a row?
Arisley
Arlington, Texas
I see what you are saying now. I would check the PCM relay, they go out like that sometimes. One of those relays in the under hood fuse box. Swap with the blower relay for testing.
dzldoctor
I would check the EBP sensor I have had them take down the 5 volt reference acting like a bad PCM.
Jomax
Arizona
But why would swapping in a new pcm fix it? Sorry, i suck at electrical. But if the ebp was bad or a relay. Wouldn't installing a new pcm do nothing?
Arisley
Arlington, Texas
When relays go bad, they will sometimes work after removing power to them. They typically fail intermittent.
Sometimes you can make them work by unplugging them and plugging them back in. I carry a spare relay in my glovebox, right next to my CPS.
dzldoctor
Technically yes, but if it relaxed or was an intermittent thing maybe enough time went and the "new" pcm fixed it for a bit. Does it communicate with scanner?
IdahoF350
Clinton, UT
If you eliminate the relay and EBP, I would also check the switch and wiring between the switch and chip, if there is a fault, internal short, or short to ground in either of those there is a possibility it could kill both the chip and the PCM simultaneously.
Sent by my right thumb!
Jomax
Arizona
New wire was put in with the new chip and pcm. I'm looking into it tomorrow. I'll let you guys know what I find
Jomax
Arizona
Does not communicate with the scanner.
Jomax
Arizona
Well, swapped in a new relay and she fired up... now the first chip did fry so maybe this was coincidence that this happened right after.
I don't thing a relay could fry and pcm or chip.
mikes02ls1
For it not communicating with scanner check to see if ur cigarette lighter fuse is burnt out. They run off the same fuse
Jomax
Arizona
Relay fixed it. I'll know 100% it was the relay after I hit the 1,000 mile mark, till then, everytime I drive it, i worry it'll die. I hate electrical gremlins.
Jomax
Arizona
If it were really a short, it should've started, correct? Is it possible the IDM is an issue?
Jomax
Arizona
Well, I'm about to light this thing on fire, died on me again. Now stuck on the side of the freeway. Pcm not getting power again... it has to be a contact loosing contact or something...
Arisley
Arlington, Texas
I had that issue for a while. Clean the contacts where the relay plugs in. I used contact cleaner and a trimmed up emery board. Use a little pair of needle nose to tighten the contacts back after cleaning.
Jomax
Arizona
I think I found my issue, two cut wires, no idea how though... after connecting them, pcm and chip powered on. Weird part is, if I disconnect the wires, pcm and chip are still on. It's almost like it takes the pcm a while to notice thus turning off after 80 miles... wires are coming out of the middle right plug (four plugs on fender liner coming from chassis and splitting off) soldering them back and hoping for the best. Fingers crossed!
Also, no codes after it powered back on...
