_DieselPower_
Okay so I have no idea whats goin on. This is the worst in the morning when she is cold started. Ill let her warm up and when I put it in drive and push the diesel pedal nothing happens. Engine does not rev it does not move. So I let off and try again. Sometimes it takes a few times and the engine doesnt rev. Some mornings itll do this and it sounds like not all my injectors are firing until I let off and try again and then it sounds normal. I dont know whats up tonight it was getting a lil worse and was having problems all day but I didnt check under the hood when I got home cuz it was a lil cold outside and dark out. The other thing that happens is kinda hard to explain but when Im going slow like under 20mph it will want to stop and idle. Im not sure if its a dirty sensor or bad oil pressure or a blown fuse or my chip is loose or if Im lost. Looking for some help on your ideas before I take it into the shop tomorrow and have a buddy look at it.
