UnrepentantSinner
- Joined
- Nov 22, 2012
- Messages
- 92
- Reaction score
- 0
Not sure what kind of braking system this is, whatever it is, it's been unhooked. Anyone have any thoughts on it?
Thanks, haven't ever seen surge brakes, just heard about them. Is there a way to convert them over to electric easily? Otherwise, I'll have to see if I can find a schematic and get these this operational again.
more or less, yes.... electric brake backing plates bolt right up in place of your current hydraulic backing plates and then you just have to run the wiring....
what i have done when i convert a trailer from surge to electric is I weld up the slider portion of the tongue so it doesnt slap back and forth....
PM me anytime, my day job is a trailer mechanic.
Do you have a source for parts. Id like to convert mine.
etrailer.com
You could convert to electric over hydraulic too.
well if someone would get that giant pile of @#$@ off of it, it might get fixedSpeaking of which... You need to finish doing the brakes on my trailer...
:flipa:
if the actuator is "clunking" its not working properly.... that means it is bottoming out which in turn means your either low on fluid and have air in the system, or your brakes are out of adjustment/wore out.....As mentioned, they are surge brakes, you can bolt on electric brakes in place of the hydraulic brakes. I would prefer that method for simplicity, because you will know what you have and the condition. Electric over hydraulic will actually stop a little harder than electric only, but the setup is more expensive then buying new electric brakes, and you may wind up having to replace several of the hydraulic components to get it to work anyhow.
I have one surge brake car hauler trailer (ex-uhaul trailer) while I do agree, it isn't as predictable or nice to pull as our electric brake trailers, but the versatility is nice. Not every one of our vehicles has a brake controller, so the ability to hook it to one of those, or lend it to a friend and still have braking is nice. Other than the annoying clunk, I have never had an issue with it, our surge brake system "free backs" meaning when you first reverse, it does lock down the brake, but they release once the wheel rolls backwards like they should.
Also, I would check out your braking system closer, the fact that the hookup has been changed to a 7 way, and I'm not sure what the black box on the left is, but it looks sorta like a electric breakaway system, I wonder if it hasn't already been converted to electric?
