forcefed6.4ford
I had 4 bent rods and the crank was warped/bent/gouged. Running HD300 tuning and gearhead tuning. Had 2 setups -stock chargers and a single 66.
If you're gonna *** it up. *** IT UP!! Haha
Did you have your injectors tested after that happened? Any indication of a headgasket failure?
i also bent rods in my first 6.4 with HD300 and lbf on 5. i doubt anyone has abused a truck as hard...it still ran even. eventually cracked a piston.
I was never against doing hd pistons, i just thought the coating was a waste of money but after seeing the video i'll get them coated too
What video?
Sent from my cracked iPhone using Tapatalk
That was kinds truck if i remember correctly. That was just horrible luck. That truck was beautiful under the hood. A very very clean build! Nice job on that truck!
Yep. Now it's a decoration piece in my office.
I have a few pieces of yours that decorate my shoplol
another guy from drayton with a modded 6.4 niice
So would de lipping lower fuel economy?
I know there are benefits, such as when tuned and the timing is advanced the burn comes out of the bowl, thus torching the lip. However the lip does help promote a more complete burn. Also tuning wise one could spread the burn out a little more. (mind you that's whats being done to begin with, hence the star pattern, now you would be more in the bowl, well kinda of as you opened the bowl up)
Then you get into injector spray pattern and that would change how you would want the bowl too.
Bottom line is for a race motor I would do it, but on a daily driver with a tune im thinking no. Or a slight delip to compensate for the tune. Now since the ih pistons have a thicker edge, do they also have a bigger bowl in the piston? Just curious if the bowl diameter in a ih piston vs a factory piston would be more likely to keep the burn in the bowl vs outside causing the edge to be torched.
Thanks
to be honest-you are overthinking it a bit. just run coated HD pistons and you will have zero problems.
LOL, What he said. I wouldn't get too technical into burn times and injector patterns on a daily driver. I agree coated IH pistons will be your strongest/best option with very little side affects if any.
