PMF Adjustable Track Bar
Kolohe
This is an older PMF Adjustable track bar
Used on a 2007 F-350 / 4WD / CCSB
About 15k on it
Has surface rust but in great shape
$200 plus shipping
Zmann
should fit 2005/20016
but there are two lengths available
OP do you remember what version this is ?
We are one if not the only company that offers an adjustable trackbar for the 2005-16. This version adjusts shorter than your stock trackbar to recenter your axle when running 5.4 or lowering coils on the front.
The lifted version will work from stock up to 4.5" of lift. This will also work on larger lifted trucks running a drop trackbar bracket. If you dont know for sure if its the right one for you, feel free to call one of our staff!
Kolohe
Not sure which length this one is. I believe this is the one of PMF's earlier track bars they built.
I purchased this track bar used from a member on this forum. I used it on on a 6 inch lift using PMF's 3 Link system for about 3 months. Worked perfectly fine. I decided to go lower on a 4 in lift and used the stock track bar which worked better in my application. Hope that helps.
