Erikclaw
I ran 60's with my TP's and it would work great with towing. EGT's were never an issue and it ran strong. Pretty much had the same additions as you are doing too.
Truck gos on the rollers either later today or tommarow for some starting numbers on the new Dyno Dynamics Dynamometer at Performance Diesel-an awesome performance shop about 10 miles from my house. Plans are to do a few pulls and then get a base number to start with. Then add a few parts; tow powers, ported heads from soot with Hamilton springs, billet pushrods, ported intake, steed speed manifolds, custom up pipes for steed speed manis from Elite, ARP headstuds, and Elite wastegate kit with welded downpipe. Stock fuel for now with this build but I have been thinking either 60'S or 85's for the nozzles. Not sure what to run with for fuel as I still want to tow and have LOTS of fun on the street and track.
Starting numbers on Dyno Dynamics Dynameter with 0 correction factor are 526hp and 1180 ft/lbs that's 591 hp corrected to dynojet
:toast:I will in fact be on the same Dyno for the after numbers as well. Things are coming together finally.
This dyno run was with stock heads, stock fuel, stock turbos, stock intake manifold, and stock exhaust manifolds and up pipes. I have two sets of everything.
im assuming the cores your goin to send back then?
not if he has paid for the cores out right...i also have two sets of everything.
:rockon: No core charges because I have purchased the cores out right my man. It is nice to not have ANY down time on the truck when it is going to be worked on.
