Possible h&s mini max problems
Ridgeville Indiana
Well the other day my egts quit reading correctly on my mini max. I am fully deleted. My mini says my egts are 32 degrees all the time. Then if you let it sit and idle it will slowly rise up to around 120 then as soon as you give it throttle it drops back to 32 degrees. I thought maybe the probe went bad. So I took another one out of dpf and changed it, with no change. So what should I look at next?
dsmracing1
Alberta, Canada
Maybe the settings got changed on the minni max i think you can choose between h&s probe or factory probe if i remember correctly....
What He Said. Go into your settings and try changing the source of your pyro. Or possibly it got changed from pyro 1 to pyro 2 on your gauge setup??
Stangr8cr
Mine had changed on me switching tunes for some reason, only difference is mine was stuck on 120. Switched from pyro 1 to 2 and everything was normal.
Keith
Ridgeville Indiana
That was the first thing I checked. But I guess it just had to cool completely off. It started working correctly today. But thanks for the suggestions everyone.
