Possible transmission problem?
Tarheel_6.4L
Memphis, TN
I'm running the H&S mini maxx on my truck with the shift schedule set to lock the torque converter up in 5th right around 56mph. The other night when I got on it, my mini maxx showed D3 TC locked. Is this normal or should I start saving for a new torque converter or transmission?
that is no problem. in fact-it is better on the trans
two things can make that happen, one is the temperature of the trans and two is the speed at which you floored it.
ckrueg
Belding MI
at higher throttle positions the converter is set to lock up in lower gears in any schedule
