POWER SEAT ISSUE!
Nic
Santa Fe, Texas
Ok, not sure if anyone else has dug this deep, but my driver side seat quit working. I have removed both driver and passenger seat from the motor and track assemblies. I tested the motor and track from the driver side to the passenger side and it works. I'm getting power to the driver side, but no power to the seat control switch. No wires are broken and harness is ok as continuity tests passed. Now, the difference in the driver and passenger side is a module box under the driver seat. There's 3 plugs that go into it. The smallest plug is merely a hot and a ground. All of what I can figure is something may be messed up in there. Seat heater control works ok, but no movement control. Any ideas?
Nic
Santa Fe, Texas
Got it fixed. The box was the memory control module which hasn't worked in a while and slowly killed a circuit on the board. I bypassed the memory module. Cutting and splicing but glad to have my power seat back up!
