Power steering hose...
CSIPSD
Bend, OR
Been rubbing on the IC tube and it lost the fight. Got a pin hole in it now...
Anyone know the cost of that little bastard? I believe its the return hose, its the one that empties into the reservoir from the brake booster.
bluedge8
Champlin MN
if you have time, you could check with sunrise ford, or Tousley Ford, if not local, I'd think that's about a $50.00 piece
Arisley
Arlington, Texas
I got it at O'Reilly's for around twenty bucks Joe. When you put it back on there is some wiggle room there, make sure it's not touching the IC tube. Make sure you check the IC tube also, might have worn a little groove in it.
I also wrapped a layer of old inner tube around the hose and zip tied it in place. Extra layer of protection.
CSIPSD
Bend, OR
$109 from ford this morning... Its the line that goes from the booster to the pump...
suprhlr
Zeeland MI
I've got a really good used one for you if interested, it came from my 00 7.3 35k miles on the truck. don't need it , doing a fummins conversion. $50 shipped
psduser1
on the road
$29 from autozone - cost more for the tools to do it on the side of the road. Dealers blow! Generally speaking.
