TxFireman1972
I went out to hook up my line for my fuel pressure gauge. Figured it would be simple, pull the plug from the test port on the fuel bowl and then install my adapter and line in place. Well I pulled the plug out, but when I went to put my adapter in, the nut on the adapter is too big and hits on the regulator housing. Anyone else had this problem?
I'm using the line and adapter from ITP that relocates the sensor to up by the firewall. I know I can just grind the "nut" down some, but was curious if anyone else had this problem.
Here is a picture of the line I'm using:
Here is the adapter:
And here is a picture showing where its hitting on the housing:
