GotStroke
I currently have and have been running a Snow Performance Stage 3 setup, until the end of last year when I swapped out manifolds with everything else. The manifolds weren't drilled/tapped prior to install for my EGT probe and I haven't taken the time to do so yet.
I have had great success with the kit when I was simply tuned and deleted. Since my upgrades EGTs have been low and haven't really needed the kit.
I am now trying to decided whether to drill and tap and use it or ditch the kit. I would like the extra cooling when on a long steep grades towing heavy but I have read recently that the water meth is bad internally for the motor?!? (Specifically rings)
I have and alway will run pure 50/50 mixture of 100% methanol mixed with distilled water, not tap or washer fluid. (Don't trust it in my engine, maybe that is what's causing issues????)
Curious whether this was just haters on water meth, people using bad mixtures( bad washer fluid or tap water) or if there is real facts behind it. I spent $1000 on the kit and would rather not chunk it but if it will kill my engine, its gone.
