Progress thread
slc dzl
Riverton, Utah
That's how I did my 7 inch miter on my black truck, slightly shorter than the cab.
There are alot of trucks here with stacks above the cab and I'm not a fan.
But on your truck duals would look great.
swinky
Eastern, Nc
I'd want a custom set done. 5 inch stainless no tips.
Sent from my SAMSUNG-SGH-I537 using Tapatalk 2
swinky
Eastern, Nc
Where is everyone buying there fuel system parts from? I'm doing an A1000 setup. RR is already on the way.
Extended Power
Whatever fittings you use, try to stay away for, Russell.
I have had everything from the -6, to the -12 crack on me.
The nuts crack. Can't see the crack until you smell fuel, and then try to tighten the fitting up...the nuts will then spread open like a cheerleader. (Junk)
swinky
Eastern, Nc
Will do. Thanks man
swinky
Eastern, Nc
from where? tank to pump 5/8" is sufficient, but -6 from pump to motor is just fine.
That's what I meant lol This whole fuel system deal is confusing me. Everyone wants like 1200 bucks for an A1000 system. I'm about to just buy a low pressure to feed the stocker and a sump. I'm only running 190/75s.
Sent from my SM-T210R using Tapatalk
Pizza pig
MD
No need for more than that. Plus its a lot easier
Hellen Keller sent this?
Marty
Elkton, MD
Had I known you were only running 75's I would have suggested something smaller then the A-1000. Call me again tomorrow and I'll tell you what you need to do to keep up with those injectors.
swinky
Eastern, Nc
This is the sensor I was sent with my boost gauge.
T into the map? Or tap the intake elbow then run hose and clamp to the sensor?
FaSSt9602
Gilbert, AZ
Wow, electric boost. Fancy!
I'd run off the elbow with some poly tube and tuck the sensor out of the way. I have always had weird readings off the MAP sensor.
