Project 1994.5 F250
Cat_rebel
Rebecca Black took my seat
Turns over nice and quick, it got a new starter?
Have you guys idled it up at all, see if it maintains that smoothness thru the rpms?
Part of the reason it might be spinning over so quickly is that there is no clutch/tranny mounted behind it. But even with that being said it does crank fast.
Had it up all through the rpm band & nothing out of the norm for an OBS 7.3 Stroker.
TheSmokinStroke2002
Hadley, Michigan
Got a back bumper and taillights for it, as well as the wiring for the stereo. Also working on getting the hardware for the interior panels and the wiring for the tail lights and tank selectors!
TheSmokinStroke2002
Hadley, Michigan
Sent from my DROID RAZR using Tapatalk 2
TheSmokinStroke2002
Hadley, Michigan
Well me and Garrett cleaned up the clutch and all that as good as we could, and we got the trans in the truck now. it wasnt a bad install at all. I am deciding to leave the body lift on, as it makes it so much easier to do stuff in there.
Got the door panels on and ext. cab windows in.
TheSmokinStroke2002
Hadley, Michigan
Me and Cat_Rebel got the trans and transfer case in. I am working on the slave cylinder install right now. Go ahead and call us the "Ricky Bobby Mechanics" LOLLOLLOL.
Oh well, live and learn.
TheSmokinStroke2002
Hadley, Michigan
after an hour of polishing on the top bar
This grill might look decent, but there are alot of little imperfection's in it. Going to need replaced most likely but i figured i might as well see what i can do with it.
TheSmokinStroke2002
Hadley, Michigan
Well I went to work on the truck here in the last few days, still can't get the clutch to bleed out after purchasing everything seperate, first bad idea. Most likely going to buy a pre bled and say *** it.
Also I have decided that I am going to do an E-fuel setup on it while i have everything apart.
