Fordguy100
I am almost positive that the check ball (some call it a ball bearing) that is in the side of the HPOP has found its way out. Lost power, and now at a hot idle the oil pressure gauge (if you can call it that) registered naught at idle, meaning less than 8psi.
Anyways, so I'm going to pull the HPOP out and fix it (tap it and install plug). What I need to know is what I need to change, and what I should change when doing this. This is on a 04 Excursion.
I have never pulled an HPOP but have literally been right there when doing an EGR delete and then again when I did the BPD oil cooler.
