ghostriderblk
- Joined
- Nov 26, 2014
- Messages
- 79
- Reaction score
- 0
hey guys,
I have confirmed I have a slight head gasket leak and I'm pulling the engine. I'm trying to get some insight with those who have done the same and what you replaced while doing so. I am going to check the heads for warping and cracks but I'm thinking other parts of the engine that need attention while its out
here's what I have so far some already done and some ordered
2005 Harley f250 auto 140k miles
truck has head studs previous owner did 1 by 1 method.
190/stock injectors
hpop fitting update
dummy plug and stand pipe update
solid turbo lines
new turbo
new oil cooler
egr ******d
4inch straight pipe
blue string upgrade
new oil rail injector o-rings
truck runs just fine ran balance test and not throwing any codes. I am going to do a compression test before putting motor in for a piece of mind to see if there's any laziness.
so far I have order a upper and lower gasket set.
(bed plate oil pan front and rear seals valve seals)
if the water pump and thermostat are ok should I replace anyways?
predictive maint. advice would be great.
thanks
190/stock injectors
hpop fitting update
solid turbo lines
new turbo
new oil cooler
egr ******d
4inch straight pipe
blue string upgrade
thanks
