Purchased a smashed 2015 6.7......
pdumont01
CT
Got hit on right side, bent the hell out of track bar on front axle, something hit oil filter it leaked all the oil out and the engine appears to be seized. Weird thing is no oil light cane on till it stalled. Anyone have any similar issues? About to pull engine and tear it down...
pdumont01
CT
Well I got the engine almost out I'll post pics of the carnage.
Sent from my Nexus 6 using Tapatalk
pdumont01
CT
Yeah there were no codes at all. I had to put the starter in and out like 6 times to move the engine while trying to turn it over with a bar. Starter got hot I burned myself a few times got a cut but I got all the converter nuts off whole front of truck off. It's basically now a long block attached to the transmission. Saturday its coming out and apart.
pdumont01
CT
its coming along...
pdumont01
CT
time to get busy!
not messin around
nothing wrong with cam or bearings
rods and bearings are fine
all but one main bearing look like new
cap took most of the beating
so did the crank
good news is the block dosnt look bad at all could be cleaned up
these look cheap and weak compared to my focus pistons and rods, may need an upgrade!!!!!
pdumont01
CT
Truck had 2000 miles on it bone stock. Everything is good except the one main and the crank. Wasn't tuned but it will be after I'm done with it. Not sure if I should send core back or keep it and build it.
Jomax
Arizona
Do you have a pic of the truck smashed?
