Question about HPFP and LPFP
weekendwarriorfsw32
Central California
Quick question. When I run my 310 tune I run 14.00's all night long but when I run my 345 tune I run 14.1's but my 60 ft are better in my 345 tune. Is this the FPFP not being about to keep up with the demamd or in my LPFP not able to feed my HPFP fast enough? Also I get a P0003 fuel volume regulator control circuit low when I run the 345 tune. If this is a LPFP issue I am thinking air dog but what one do I want?
Thanks
Nick
benbou00
Louisiana
I was getting that code too. My truck is in the shop right now because of this and I'm pretty sure the HPFP wire harness is bad on it. My truck got as bad as stalling out on me and would just kill.
weekendwarriorfsw32
Central California
My truck was doing that and going into a "limp" mode but got a new HPFP and wire harness and that fixed that but I got this code after and only at WOT on the track in 345.
benbou00
Louisiana
Mine only threw the code twice while I was just cruising and then got down on it. A few weeks later it then started acting up on me. I have a modded pump in mine so it may not have anything to do with the HPFP.
I see rail pressure of about 24,500 with the 345 and with the 310 it'll spike to around 28,000 and won't go any lower than 25,000 I think. It's been a while since I've driven it so I don't really remember the exact numbers.
Ipkyss
Thanks
Nick
Are you running the kem 310/345 or the Spartan 310 and the Kem 345? I would not expect the Kem 345 to be faster then the Spartan 310. With a stock fuel system, I don't get any codes even running the Spartan 350. I would guess the code is more related to the kem 345 then your truck.
Dzchey21
wyoming
You really need to watch rail pressure at wot before we can be much help.
Sounds like the pump might be starting to get a little tired, but i have had my truck not maintain pressure at all with no codes or anything... so my guess is alot of it is tuning
WoodBoy
Alabama
I thought the whole time the 310 has always been a faster tune? Plus the 345 makes its power down low hence the better 60'
Dzchey21
wyoming
24500 is perfect so i would say your fuel system is ok, try the 345 and let us know what happens
Dzchey21
wyoming
desired with all tunes to my best knowledge is 24500, so what i would do now is run that 345 and check low pressure fuel and see what it falls to when the rail pressure falls to 22k
