brian89
If you could build any truck would you build a race or pulling truck and why? What motor and setup would you use?
Most likely it'd be a 4wd SCLB, possibly SCSB, built 7.3, PCS'd BTS 4r. But i would not build a truck to do just one thing, like sled pulling. If possible i'd have 4 link front and rear, good hitch set-up, removable weight bracket, and removable suspension stops. Have 2 sets of wheels for it, one would be DRW with some meaty tires, and another set would be something light with sticky rubber.
Then i can go out and rape on the track, rape on the strip, and kill some flat biller's dreams on the drive home.
Although doing both would be fun to do its near impossible to have a truck to do both sports and be a top runner at each one. It pretty much has to be dedicated to serve one purpose if your goals are to be competitive
True. Although i think if you get everything perfect and dialed in as good as possible, you could build a competitive 2.6 truck that could still run good on the street and strip. You may not go out there and set any records or bring home many trophies, but just be competitive and have fun while your doing. Personally i'd much rather have a well-rounded truck that is good at everything, than a truck dedicated to just one thing. Unless of course i had the cash to afford multiple trucks, and the time to build and dial each truck in.
Or i could just drive a clean, stock OBS with a big retirement fund waiting on me. LOL
Competitive 2.6 trucks that u can still drive on the street are a thing of the past.
All depends on where you are pulling. The truck that won my local fair this year was about 700hp. Where you pull is a different story though lol
Which fair was that? I'm from chambersburg PA by the way
