Radius arm drop bracket install ! HELP !
Tom-Teezy
I need to add radius arm brackets to my 2012 f250 and was curious if they could be installed without removing the coil and shocks ?
yes.
assuming you have already done the spacers or coil portion of your lift.
all you need is two floor jacks and you're golden
Zmann
shouldn't be a problem
you may need to remove one of the radius arm bolts from the top mount at the axle so the radius arm will drop without trying to pivot the axle then when you do the next bracket the radius arm will turn the axle and realign the mount for the first radius arm
if your on a lift or jacks and stands you could do them in concert without undoing the radius arm at the axle
if in a driveway the first method is safest IMHO
Tom-Teezy
Thanks guys ! Yes I have the coils and shocks already installed and come to find out I have to have the drops and I really dnt want to remove all tht if I dnt have to !
Zmann
it's not bad I did 4 links and removed my drop radius arm brackets and arms in my drive way
about 3 hours yours will be even quicker IMHO
Tom-Teezy
My only prob is my truck is supported by jack stands on the frame right behind the stock location so it's gonna be tricky to restand it in order to get the bracjets in ! I'm also not taking off my shocks or coil because it will be too much if I tried to do all that !
there is no need to remove coils or shocks in fact its probably easier with them in because then the axle doesn't move around as much.
if your stands are behind the factory mounts, there should be no clearance issue.
put a floor jack under the radius arm so when you pound the bolt out it doesnt drop and lower it slowly out of the way. install the drop mounts and then lift it back up into place.
Tom-Teezy
But from what I saw in the instructions u have to remove the transfer case skid plate which is right where my stands are
And my coils have a bad bend in them which is why I need the brackets so when I take the bolt out of the arm at the frame it rotates more forward so I have to hopefully rotate the axel backward in order to line it up
Zmann
I was wondering if you had the Procomps that attach at the cross member
I read the directions for those real fast
mine were much more simple and worked just fine .
the coil bend is normal IMHO and a little twist in the radius arm axle isn't going to fix it ( compress any coil spring at both ends and it will want to bend out )
you do the drop to gain the caster adjustment
as far as your stands being right at the cross member I don't understand ? I did the whole deal with no jacks or stands if thats what your referring to
but I didn't have to unbolt the cross member
I would take a pic but I have removed all of that in favor of a 4 link
Tom-Teezy
My coils are bending so much they touch my front shock on my dual setup ! So when I rotate the arm down it takes enough of the bend out to get it off the shock . And my truck is on stands w the back wheels on the ground and the stands right behind the radius arm bracket on the frame .
Zmann
that is crazy coil deflection
couple of questions
1 did the coils get set properly into the coil seat at the bottom ?
2 is they something holding the coils from extending ?
3 if your axle was that twisted I would think your alignment would be fubared ?
4 confused why you have jackstands in place now ?
Tom-Teezy
couple of questions
Pretty sure they are seated in the bottom correctly
I have a spacer on top of the coil
No wheels on the front due to coil touching front shock so it's still on stands
I think my main prob is the arms with my 8" kit are too short to compensate for the extra 2.5" coil causing it to pitch more forward making it contact the shock
Zmann
well the coil may be rotated in the seat from when u did the spacer ?
I am not sure that would cause your issue since I have never installed a coil in the wrong orientation to see what happens but they do have the internal ramp to match the coil bottom for a reason
