RCSB thread.
Twinturbostroker
El Paso, Tx
Has anybody gone static more than than the standard 3-5 drop? I slam the frame with the axle when I have a load on, so I am planning to c-notch and add helper bags in the rear. I am thinking about going down another 2" all the way around. Thoughts?
Why not 4-link bag it?
03mm
FL/MD
Been thinking about selling my bed cover and getting a Old Skool Fab single stack. What are yalls thoughts?
Twinturbostroker
El Paso, Tx
Been thinking about a stack too honestly......but if I did it, I'd keep it low, maybe some where between the level of the bedsides and half way up back of the cab window
03mm
FL/MD
Yea I was thinking of there short stack. It's like 2ft and then use the mount to adjust how high it is.
the mess on the back of the cab may cause you to re-think that proposal...
BWCbuilt
central US
I have gone back and forth on doing a stack, but I really like how my exhaust turned out. It is hidden very well, and gets the soot away from the truck.
03mm
FL/MD
He has it on Instagram: JORDAN1SLO6OH the only things I think he has done 08 tailgate, roll pan, and led under lights.
03mm
FL/MD
One of the other shots I took when I was trying to get a good one to submit.
Bad_company
OK good sirs if its been explained I'm sorry... I haven't read the whole post but please explain your set ups... What tank? what lines? what bed? Who much did u cut? What were problems u ran into? Bumper and hitch mounting? Going to be starting a rcsb project soon. Also I have a 5th wheel ball that I want to get rid of... Any helpful hints would be awesome! Thanks in advanced!!!
Twinturbostroker
El Paso, Tx
OK good sirs if its been explained I'm sorry... I haven't read the whole post but please explain your set ups... What tank? stock 29 gallonwhat lines?stock fuel lines just cut and reflaired male/female what bed?stock 6.75"ft bed Who much did u cut? 8ft bed to 6.75ft bed kinda easy math, just mock fit the short bed to the cab so you're not too close before final welding What were problems u ran into?you'll need a new driveshaft and to do something with your e -brake Bumper and hitch mounting?stock location? Why would that move? Going to be starting a rcsb project soon. Also I have a 5th wheel ball that I want to get rid of... Any helpful hints would be awesome! Thanks in advanced!!!
And here are some updated pics of how it stands today
