Rear block swap question
Spderjhn
I am going to buy f350 rear blocks for the f250 and remove the stock block and spacer original owner had. Do I need anything other than the blocks and ubolts ?
INFRNL
Colorado
Yes, you just need the blocks and proper length ubolts. some trucks have the overload spring, so the ubolts would need to be longer than a truck without.
Also if you have a tapered block now, you will most likely want a tapered 350 block. If its flat, then you want a flat block from what I've been told
Spderjhn
Why would some blocks be tapered and others not ? On the f350 does it have to do with packages ?
Spderjhn
Next question why is the left block $20 cheaper than the right block for the f350
Sent from my iPad using Tapatalk HD
Super08Duty
College Station, TX
ford is weird when it comes to pricing parts. most of the time, parts for one side of the truck are different then the other side. theres no difference in the driver side and passenger side blocks. unless the blocks that come on trucks with overloads are different for some reason.
