Rear diff service
94.5 Stroker
Lincoln, Nebraska
Planning on changing the fluid tomarrow and installing an 08 diff cover. Was just curious what fluid I should run? Truck has almost 221k on it. I was thinking about Lucas.
Thanks Cody
FORD7.3
im running mobil-1 synthetic in 75-140 and love it, hope you have longer bolts before you start this project.
FORD7.3
Forgot to add a picture and the size of the bolts, im running allen head bolts but you just need something longer, size I used was 5/16-18x1.25
Pstroke96
Connecticut
im pretty sure its 3.5 qts in the rear, plus 8 oz of friction modifier, put that in first then fill it with oil till it dribbles out the hole
gnxtc2
Bergen County, NJ USA
I've heard not to use the friction modifier if the rear clutches have alot of miles on them. The modifier makes the worn clutches too slippery.
My truck has the Traction-Lok rear (204K) and only one tire spins when it starts to slip.
Billy T.
[email protected]
