Rear leaf spring hanger
gnxtc2
Bergen County, NJ USA
I need to replace the rear leaf spring hanger on the 1997. I had to notch the shackle to clearance the SD springs.
My question is...does the SD spring hanger holes line up with the OBS frame so I can swap over to the SD shackle?
Also, there was talk about the van spring hanger with the SD shackle but I can't find that thread.
Thanks
Billy T.
[email protected]
Peroni
North Carolina
The SD hangar does not line up to the OBS frame bolt pattern.
The van shackle is used with the OBS hangar.
Sky Offroad makes a HD shackle for use with stock springs and a HD shackle to use with SD springs, both using the OBS bracket.
Got4wd
I came up with this. You use the van shackle, don’t remember the year pre 91 I think. But don’t hold me to that. I just had to drill out the spring side for the bigger super duty bolt.
Got4wd
