rebuilding factory turbos?
oneturboforme
id like to rebuild my factory turbos and put some batmos in it.. whats it take to do this? can it be done diy or does it need to be taken to a performance shop... thanks
blk350on20s
Try not to hijack but if the arm for the vgt is busted off the turbo can that be replaced?
I know back in 08 i bought a set of turbos and nothing rebuild wise was available.
Dzchey21
wyoming
You can take the comp wheels off and no worry about balancing but the turbine wheel is balanced with the shaft as a complete assembly.
The comp wheel is balanced seperatly too. Best thing is balanced as an assembly but most turbo builders don't do that.
